Acer Nitro 5 0% battery when using charger and without charger not starting
Anuj195
Anuj195 Member Posts: 4 New User
So I have this problem with my acer Nitro 5 2021 from past 2 days where laptop shows 0%charging when plugged in to the charger. I had a servicing from acer certified center 2 weeks ago regarding rainwater but the issue was solved as no water seeped inside the laptop and the service centre did full servicing of the laptop and now this problem.
IMG_20230402_221503.jpg There was an error displaying this embed. There was an error displaying this embed. There was an error displaying this embed.
  • sri369
    sri369 ACE Posts: 2,894 Pathfinder
    Check the battery wear. You can use a tiny utility like battery bar. Maybe your battery got totally discharged and is gone kaput.
    Karma...
    LIKE - if helpful
    ACCEPT - if helped resolve
    Puraw ACE, Member Posts: 17,588 Trailblazer
    It looks like your battery is dead. Create a Battery Report in Windows by typing or pasting the following line in the Command Prompt: powercfg /batteryreport /output %USERPROFILE%\Desktop\battery_report.html
    Open the file "battery_report.html" on your Desktop (double click) and look at the Full Charged Capacity, if that is very low or blank you need to replace your battery ($50)
  • Have you tried disconnecting the battery from the motherboard?
  • Anuj195
    This are my reports can anyone check them for any discrepancy
  • Anuj195
    Yes I did but the issue still
    Incomplete, please sent the whole report not a screen shot.
