Acer Nitro V Blinking battery/power lights, charger Issues again?
Seqaeon
Seqaeon Member Posts: 1 New User
edited July 29 in Nitro Gaming
Any one have any idea what could be causing it?, this is the second time Ive had charging related problems with this PC, last time my charger got burnt in a weird spot, now my new charger, a completely different type seems to be shaking as well as the blinking lights thing.
r/AcerNitro - Battery and Power Light Blinking Acer Nitro V r/AcerNitro - Battery and Power Light Blinking Acer Nitro V
First Charger
Second CHarger
    Puraw ACE, Member Posts: 18,175 Trailblazer
    Hey @Seqaeon — sorry to hear the charger woes continue. Just a quick tip: adapters with straight-angle plugs tend to be more durable, especially with setups where the cable gets bent or tugged frequently. Strain on the connector or cable head can silently wear out the internals over time, even if the outer casing looks fine.
    If you’re grabbing another unit, might be worth picking one with reinforced strain relief or a straight plug design to give it a better shot at longevity.
    Also—make sure the plug fits snug and doesn’t wobble in the port. A loose connection can create micro-arcing, which definitely wouldn’t help those blinking power lights.
