Battery drains quickly, laptop won't turn on without power and charging starts at 40%
matias97
matias97 Member Posts: 6
edited December 2024 in Predator Laptops
I have been using my laptop since January 2024. When I unplug the computer, the computer turns off in approximately 3 minutes and the battery goes down quickly.
In the morning it does not turn on if it is not plugged in. The strange thing is that when I charge it, the battery instead of charging from 0-100 starts counting its charge from 40% battery... as if it already had
  • Axxo
    Axxo Member, Ally Posts: 2,113
    A typical laptop battery life lasts up to 3 to 4 years. In one charge, a laptop battery should run 4-6 hours considering moderate usage. But with regular care and a certain amount of attention to some particular settings, one can significantly increase the lifespan of a laptop battery.
    Windows 10 has an in-built battery saver which saves battery life a lot. When it is turned “ON” from the Settings it will lower the brightness, stop all the syncing tasks, and freezes unnecessary and power-hungry applications running in the background. You can use Battery Saver just by following these easy steps-
    1. Click on the Notification Center icon on the right bottom corner of the Task Bar and click on the “Battery Saver” tab.
    main-qimg-fa68ae19dcccc4b22ada15d27b7797be
    You have to customize the Battery Saver settings from your computer.
    2. To do so, press Windows Key+I to open the Settings window. In the Settings window, then click on “System“.
    3. In the Settings window, click on “Battery” on the left pane. Now, Arrange the battery limit, which when will be crossed, Battery Saver will be turned on automatically.
    4. Click on “OFF” to turn on the Battery Saver “ON“.
    Tips to keep your laptop battery in good health:
    1. Prevent It from Dropping to Zero
    2. Activate Battery Saving Mode
    3. Keep Your Laptop Away from Extreme Weather Conditions
    4. Unplug Unused Peripherals
    5. Turn the Wi-Fi and Bluetooth Off
    6. Lower The Screen Brightness
    7. Avoid Leaving Your Laptop Plugged In
    8. Install the Latest Operating System
    9. Close the Apps That Consume More Power
