Boot problem on ACER ASPIRE 7 a715-76g does not turn on after shutting down when using battery power
Jeelani
Jeelani Member Posts: 6
edited November 2023 in Aspire Laptops
My Laptop does not turn on after shutting down when using battery power. When pressing the power button a light blinks. However, it turns on after plugging in the charger. Once the laptop is turned on, I can remove the charger and the laptop will continue to work fine?
  • I advise updating the bios:
    BIOS
    Optimize battery charging behavior
    Acer
    2023/02/21
    1.08
    8.43 MB
    Download
  • Jeelani
    BIOS updated but problem not solved.
  • Have you tried disconnecting and reconnecting the lithium battery?
  • YusaArifki
    YusaArifki Member Posts: 4 New User
    Hi @Jeelani, have you tried this?
    does your problem already solved?
    i just have these same issue recently.
  • yogeshraja
    yogeshraja Member Posts: 1 New User
    I too have the same issue.
    I have done many troubleshoot methods to resolve it but yet it doesn't resolved.
    So I contact the customer support which is a toll free number (+911800116677) and they give me a case id to change my motherboard.
    Due to the insufficient power delivery from battery to board this issue occurs or there may be a chance that your battery condition is not good.
  • MRCREEP
    MRCREEP Member Posts: 1 New User
    Guys you guys have to actually try
    here's the solution:
    • When you press the power buttons and it flashes 5 times
    • Holds the power button for 15 - 20 seconds until a purple or white light flashes at where the blue light flashes
    • Happy computer for you guys!
    Puraw ACE, Member Posts: 17,733 Trailblazer
    Like yogeshraja suggested, the battery may be bad or the power adapter is not powerful enough to charge a depleted battery. Run a Battery Report in Windows and see what the charging/discharging profile looks like, if the last full charged capacity is far below the design capacity, consider replacing the battery and/or try to charge with different power adapter with a compatible barrel power pin for your DC port. If the Acer warranty is still valid I would not open the laptop as that may void the warranty. This is what the LEDs indicate:
  • Oi! Eu não sou sou a cortana! Mas estou aqui para ajudar! Hi! I'm not the cortana! But I'm here to help!
