My Swift 3 SF314 43 R79B won't turn on tried holding power down, pin in battery reset but nothing
LindaB2021
LindaB2021 Member Posts: 3 New User
Tried above solutions but still,nothing. Happened last year in Portugal, left it abouta week after think jing I'd wait till I got home then out of blue it worked. Benn fine since but Now,in Thailand and its happened again. Happens after trying to charge. Help
    Do you get any indication lights with the charger connected? Are the lights solid or blinking, and which colors? You might be dealing with a bad battery, a bad charger, both or maybe even a problem with the power key...
  • LindaB2021
    There was absolutely nothing and then I tried to power up and it just started as if nothing had happened!!
  • leonaip
    leonaip Member Posts: 417 Specialist WiFi Icon
    report it Acer service center near you and avail the warranty
    else
    buy new battery and charger of the same model/specification
    else
    buy compatible ones if you wish but will void the warranty
    If my answers/solutions help you, please consider hitting "Like" and "Yes".
    Regards and God speed 😉
    Acer Nitro 5 AN515-58
    - Intel Core i5-12500H 12th gen Octacore ( 2.70 ghz... Turbo up to 4.50 ghz ) with p-cores and e-cores
    - 15.6 inch thin bezel IPS FHD ( 1920X1080 ) 144hz
    - RAM 8 GB DDR4 MAX 32 GB
    - SSD 512 GB Nvme
    - Nvidia Geforce RTX 3050 ( DEDICATED 4 GB GDDR6 )
    Keep an eye out for any other anomalies and let us know. It could still be any of those issues, but just intermittent.
  • LindaB2021
    Turned laptop on yesterday and used fine. No need to charge so tried again today and nothing _ no lights no power, nothing.
  • leonaip
    try a spare or new compatible charger first.
    if problems persist, let a skilled tech troubleshoot it.
    - SSD 512 GB Nvme
