Acer AspireF5 573G-Battery is completely dead-write technical details, Voltage and Mah power?
Justyna
Justyna Member Posts: 1 New User
edited May 30 in Aspire Laptops
Dear Sirs,
Battery in my Acer Aspire F5 573G is completely dead. Can you please write technical details of the battery I need to buy.
What Voltage and Mah power?
Kind regards,
Justyna
[Edited the thread to add model name and issue detail to the title]
  • AnhEZ28
    AnhEZ28 ACE, Member Posts: 5,066 Pathfinder
  • Axxo
    Axxo Member, Ally Posts: 2,000
    If the battery in your Acer Aspire F5 573G is completely dead and the laptop won't turn on, you can try a few troubleshooting steps before replacing the battery. First, ensure the power adapter is plugged in and the laptop is plugged into a working outlet. You can also try a hard reset by pressing and holding the power button for a few seconds, and then attempting to turn it on again. Additionally, you can check the battery health in the BIOS or by using Acer's troubleshooting guides.
    Troubleshooting Steps:
    1. Check the power adapter and outlet:
      Ensure the power adapter is securely plugged into both the laptop and a working outlet.
    2. Hard Reset:
      Press and hold the power button for about 15 seconds to force a shutdown, then try turning it on again.
    3. Check Battery Health:
      Access the BIOS settings (usually by pressing a key like F2 or Delete repeatedly during startup) and check the battery status. Some BIOS versions may also display a battery health indicator.
    4. Try External Storage:
      If possible, try booting from an external device like a USB drive with a bootable operating system to see if the laptop can be powered on.
    5. Inspect charging port:
      Check the laptop's charging port for any damage or debris that might be preventing it from charging.
    6. Test with another charger:
      If possible, try using a different power adapter to see if the issue is with the original adapter.
      If none of these steps resolve the issue, the battery may need to be replaced. You can find replacement batteries for the Acer Aspire F5 573G online or at computer repair stores.
