About Acer monitor S242Y ultra-thin wall mount. please provide me wall mount solution.
aditech
aditech Member Posts: 4 New User
edited May 10 in Monitors
I have bought Acer S242Y ultra thin but it has only 2 holes for wall mount and I am not able to find any such compatible wall mount in India. Please Acer team will provide solution for this.
    StevenGen ACE Posts: 15,012 Trailblazer
    The S242Y that you have has a different base mount then the one that Acer has a service guide for which has a round base plate mounting (see caption below) and has screw holes and provision for a wall mount bracket. Your S242Y model monitor Acer has no service guide on that model, so you will have to figure out a bracket that will fit your monitor.
    The S242Y monitor back plate that your monitor has below is not the same as what Acer SG described model below.
    This is the Acer SG back plate that Acer has for the S242Y monitor in its service guide.
    billsey ACE Posts: 36,341 Trailblazer
    We need the full model number off the sticker in the back. It will have more letters and numbers after the "Y", and potentially another letter or two before or after the "S".
  • aditech
    I want to wall mount it and not table mount it
  • aditech
    I am not able to find its wall mount anywhere in India and if you order it from another country, it will cost you the same as the price of the monitor
    We can only suggest to have you contact Acer support for India. India has a lot of models that aren't available elsewhere in the world, and we don't have access to technical details on those.
