BEST power plan for Nitro 16 AN16-51-72LX? | Missing OEM Power plan after reinstall
EpicUser99
EpicUser99 Member Posts: 2 New User
edited March 14 in Nitro Gaming
I reinstalled windows using an external usb instead of doing a factory recovery. I formated all partitions possible but the recovery one, so when windows ran for the first time after reinstall i noticed half of the OEM things and programs you would usually get with a factory reset were gone, including the power plan, which i need a lot because it was ridiculously well optimized, and i cannot seem to replicate it's efficiency or find it anywhere else, as it regulated the processor power to the lowest it could without losing any performance (only while plugged in, when i ran games on battery i would use the high performance power plan as on battery power everything ran really limited) , which meant that i used to get 37C temps on desk unactivity (browser, spotify and discord open, including rainmeter animations like fountain of colors WHILE listening to music, and using hwinfo running in background to display temps using rainmeter, and like other 3 programs running in background. The gpu would run at 780mhz in the heaviest games of roblox i know. On PUBG with ultra settings and limited framerate to 80 fps i would barely get temps avobe 60C. This post was originally just meant to ask to see if somebody could export their power plan from that specific model, as it seemed to be the best, since i have been testing other nitros and predators power plans setups myself, but i decided to doccument my experience with my power plan.
For anyone who can export the acer power plan (Specifically the one of the model mentioned, down to that last 72LX) or actually, i think that as long as it's the same model it should work regardless if it's the 3050 or the 4050 model one.
Here's a tutorial for exporting power plans.
https://www.youtube.com/watch?v=ebsuZJ8oGqw&t=59s
  • EpicUser99
    Also yes, i would get really good FPS while using it. I do not know if some other plans gave more fps but one thing is for sure, due to this plan not thermal throttling everything it touches, you'll get a ridiculous performance at a really quiet fan level, and that's what makes it special imo. If anyone's curious, i might test it aganist the high performance power plan, maybe even the ultimate performance power plan to check on the differences. But the acer power plan saved me from having force an undervolt, as i would get lower frequencies and voltages on idle than if i did wizardry with throttle stop (0.790-0.830v, 1200mHz was the lowest i saw) . I would also like to just have it because i imagine OEM power plans are tuned based on hardware rather than software, which is why i assume i had better results with my OEM acer powerplan than foreign ones also from OEM acer.
