chrombook Not charging, it says low power charger connected
Rakki06
Rakki06 Member Posts: 1 Newbie
edited 5:56PM in Chromebooks
What should i do ?
  • Jack22
    Jack22 ACE Posts: 4,307 Pathfinder
    @Rakki06
    Use a high power charger or use the charger which came along with the Chromebook
  • Sharanji
    Sharanji ACE Posts: 4,537 Pathfinder
    @Rakki06
    The "low power charger connected" message on your Chromebook indicates that the charger you're using isn't providing enough power to charge the device properly. Here are some steps you can take to resolve this issue:
    As Jack22 mentioned above, ensure you're using the original charger that came with your Chromebook. Third-party chargers might not provide the necessary wattage.
    Inspect the charger and cable for any signs of wear and tear. Sometimes, a damaged cable can cause charging issues. Try using a different charger and cable that meet the required power specifications (usually 45 watts or more).
    Dust and debris can accumulate in the charging port, preventing a proper connection. Use a can of compressed air to clean the port gently.
    Ensure your Chromebook's operating system is up to date. Sometimes, software bugs can cause charging issues.
    Perform a hard reset by holding down the Refresh button and tapping the Power button. This can sometimes resolve charging issues.
    If these steps don't resolve the issue, it might be a hardware problem, and you should contact the Acer Support or a professional repair service for further assistance.
    billsey ACE Posts: 35,577 Trailblazer
    You don't tell us what Chromebook you have, so we can't lookup specs on the charger you need. Your full model number is usually on the same sticker as your serial number, it should look something like xxxxx-xxx-xxxx.
