Hello Acer Community,
I'm experiencing a frustrating issue with my Acer Nitro 5 AN515-57-7296 laptop, and I'm hoping someone can offer some guidance.
My laptop (originally with an AP18E8M battery) had been unused for about a month. When I tried to turn it on, the fan ran at full speed, I heard a clicking sound, and the laptop shut off. I took it to a repair shop, and the technician diagnosed a charging circuit issue.
After the repair, the laptop would only turn on when the AC adapter was plugged in. The technician then recommended replacing the battery, as they said the old one was weak. I replaced it with a brand new battery.
However, the problem persists. Now, the laptop turns on with the adapter, but the battery doesn't charge. For example, I plugged it in at 12:30 PM when the battery was at 50% and showing as charging. At 1:00 PM, it was still at 50% and still plugged in, but the charge level hadn't changed. When I unplug the adapter, the laptop runs on battery power, and the battery percentage decreases as expected.
The technician has checked the laptop a second time after I reported this issue, but he insists he can find no further problems with the charging circuit.
So, to summarize:
- Laptop Model: Acer Nitro 5 AN515-57-7296
- Original Issue: Charging circuit failure, clicking sound, fan at full speed.
- Repair: Charging circuit supposedly repaired.
- Current Issue: Laptop only powers on with the adapter. New battery doesn't charge, even after a second check by the technician.
I've already replaced the battery, and the technician has re-checked the charging circuit, so I'm unsure what the problem could be. Could the repair have been incomplete? Is there a setting I'm missing? Could there be a separate issue at play? Any advice or suggestions would be greatly appreciated.
Thank you for your time and assistance.
