Some history on the laptop, I spilt water on it, it died and wouldn't boot. I opened it up and cleaned the motherboard with isopropyl alcohol and it started working again, however the battery would no longer charge but it still drew power from it. I was fine with this since I mostly used it plugged in anyways however it slowly began to die from more demanding games until it now can barely browse the web before dying.
I got a new battery and cord to test if that would fix the problem, neither did. initially I thought it was a heating issue, but it seems to be a power draw issue. I can occasionally get the battery to charge by unplugging the cord and replugging it multiple times while booting up. While the battery is installed and I try to play a game it'll start beeping then the orange and blue lights flash, then the charging icon disappears while the cord is still in, then it dies. I have tried everything I can find online from hard power resetting multiple times, as I have to when the lights start blinking, to resetting the bios. I have noticed when I plug in the new battery to the terminal it now sparks a bit, but that's more recent and didn't happen before and hasn't really changed anything.
With no battery installed it'll do the same, whenever it draws more than 30w it dies completely, without flashing any lights.
Is this something that can be resolved software side, or do I have a dying board?
