I work in a school IT dept and need to know to order parts for chromebooks
FCS_1986
FCS_1986 Member Posts: 1 New User
edited February 2024 in Chromebooks
    StevenGen ACE Posts: 15,247 Trailblazer
    Which Acer Chromebook models does your school have, as parts are available but the first task is to make a list of the Chromebook laptop models that you need parts for, then know which parts you are after, then you can get these part numbers when you contact Acer in your area or search the web for those parts, this is the easiest way to get all the parts that you need.
    We won't have any real insights into that, since we are all just other Acer users. Your best bet is to get a list of local suppliers for your locale from Acer support.
