my acer A115-32 wont turn on and wont display and LED lights on side
A_8
A_8 Member Posts: 1 New User
edited February 2024 in Aspire Laptops
I use my computer to play video games and one day (like a week ago) it wouldnt turn on and the display lights on the side were not showing anything even though i put it on the charger before and it was at 100%
please help
    Puraw ACE, Member Posts: 17,567 Trailblazer
    As the standard Acer Warranty has probably expired try the following: there is a small pinhole in the back of your laptop (with a battery sign) and stick a pin in that hole till you feel it click (micro switch), keep pressing the pin for a few seconds. This will reset the battery. If you still can't boot.
    Power drain + CMOS reset: Open the back of the laptop and disconnect the battery cable from the motherboard. Locate the CMOS module (with 2 twisted wires Red and Black) and remove the coin battery. Shorten the +/- contacts inside the CMOS capsule for 2 seconds with a bended paperclip and put the coin battery back with the + sign facing up, close the CMOS capsule. Unseat the two DDR4 modules and secure firmly back in the slots. Next, press the Power Button on the keyboard for 10-15 seconds after that reconnect the battery cable to the motherboard. Close the laptop, plug-in the adapter and try to boot.
