n50-610 nitro 4pin on my motherboard not working? fans does not have any power from motherboard 4pin
Moe212121
Moe212121 Member Posts: 4 New User
edited December 2023 in Nitro Gaming
Why does my 4pin on my motherboard not working? i have a nitro n50-610 and the fans does not have any power from the motherboard 4pin and i have bought a new fans but it still not working? Anybody knows why?
    StevenGen ACE Posts: 14,706 Trailblazer
    Which fan plug is it? Is it the Heatsink CPU fan plug at #21 or the Case fan plug at #26 below, as there are two plugs on the N50-610 mainboard (see caption below and parts). Check if the mainboard plug trace is not broken or the plug is not broken from its connection or you have a faulty plug at the mainboard, as that could be the problem and the fan plug needs replacing by an experienced technician. Or and if you don't want to spend the money to fix the plug, connect the fan to the other fan plug with an adapter onto your N50-610 mainboard. Good luck and hope this helps you out.
    N50-610 mainboard cpu and case fans plugs
  • Moe212121
    Thanks but it did not work i have bought new fan's and tried and it still doesn't work and i tried to connect it to other 4pin adapter on the motherboard but still not working.
    This is my motherboard btw
