When I press the power button the power led blinks once then it dies (Model: A314-32)
kurenaikurumi
kurenaikurumi Member Posts: 3 New User
When I press the power button the blue led blinks once then it dies. If I plug the power cable (the orange lights up so I think it works) and press the power button the blue led blinks once, dies, then blue led turns on again but there's only black screen.
  • kurenaikurumi
    More Info:
    1. If I remove battery and plug the laptop it won't turn on (No blue light)
    2. If I charge the laptop for a while then unplug, pressing the power button will make the blue led blink once then it dies, then it turns on again but still no display (black screen)
    3. Tried connecting it to another monitor with HDMI but there's no signal
  • kurenaikurumi
    More Info:
    1. Resetting BIOS did not fix it
    2. Pressing the power button starts up the fan but it dies, when the blue led turns on again the fan starts up but dies later on with still the blue led turned on
    Puraw ACE, Member Posts: 14,727 Trailblazer
    I recommend bringing the laptop to Acer Services in your country.
  • It could be a short in the 19v line. This usually happens on 19v input mosfets.
