Why does the power LED on my A314-32-C4H0 blink when I press power?
_QQ_
_QQ_ Member Posts: 2 New User
My laptop's power light(blue) blinks 5 times when I press on the power button. The laptop doesn't turn on even when I have it plugged in. Holding down on the power button doesn't seem to do anything.
Is there a way to fix this?
    Puraw ACE, Member Posts: 17,733 Trailblazer
    Assuming this is still the original power adapter that came with your laptop: The specs should be 19 v 45W, 5.5mm x 1.7mm barrel, yellow tip?
    If your laptop is >4 years old and you have not yet replaced the battery I think that is the first suspect for not being able to power up. Unplug the Power adapter, open the back of your laptop and disconnect the battery cable from the motherboard with your finger nails (sometimes this connector is very tight and difficult to unplug). Now press the Power Button and keep it pressed down for 1-2 minutes to discharge any statics, wait a few minutes and put the back cover temporarily back on your laptop without screwing. Plug in the power adapter and press the Power Button again to see if you can start without a battery. If that works, unplug the adapter, open your laptop and connect the battery cable to the motherboard again.
    If you cannot start with the battery even with the power adapter I recommend that you replace the battery.
  • _QQ_
    It's working now, I just waited for a few minutes. Thanks anyway! c:
    Good to hear this.
    I would still run a Battery Report in windows, type/paste the following line in the Command prompt
    powercfg /batteryreport /output %USERPROFILE%\Desktop\battery_report.html
    Open the file on your Desktop (double click) and see what your full Charged Capacity was the last day.
  • William_mk2
    William_mk2 ACE Posts: 4,198 Pathfinder
    @_QQ_
    In future if you face any issues in turning on the computer. Kindly follow the steps given below
    I am really sorry for the inconvenience..   Let us do the basic steps first..
    Doing the power drain and bios defaults will really help.  Kindly follow the steps given below:
    Turn off the laptop. Disconnect or unplug the charger cable, devices or any other cables connected to your laptop. Close your laptop. Turn it upside down.  On the bottom of the laptop, you can find a  pin hole. It is a tiny hole. You can a find a battery symbol indicator next to the hole. It is like a + and – sign symbol as though somebody is trying to shift the battery out. Insert the pin on to the hole for 30 seconds. Remove the pin. Flip the laptop. Connect the charger cable, turn on the computer.  Only on laptops where the battery is inbuilt you can find the battery reset hole on the back of laptop.
    If you don’t find a pin hole on the back of laptop then you might be using removable battery. There is no need to unscrew anything to remove the battery.  Turn off the laptop. Disconnect or unplug the charger cable, devices and any other cables connected to your laptop. Close your laptop. Turn it upside down.  On the bottom of the laptop, please look at the top or bottom depending on the way you look at it. You can find a long door. It is a battery removable door.  Just below that you can find a latch.  If you move the latch you can remove the battery door. Once the battery is removed, flip the laptop. Open the top cover, press and hold the power button for 1 minute. Connect the battery back on the back of computer. Connect the charger cable back and then turn on the computer.
    If you don’t see a reset pin hole on the back of laptop or if you are not able to remove the battery (if it is inbuilt) then please unplug all the cables and devices out of laptop.   Hold the power button for 1 minute.  After releasing the button you should wait a while before plugging in power. Just because the button has been pressed doesn’t bleed off all the residual electricity on the motherboard. Wait 15-30 minutes before plugging in power. Then once power is connected wait for a full battery indication before turning the system on. That allows the battery to fully reset it’s internal statistics.
    Connect all the cables back and restart the computer.
    While turning on the computer, tap f2. It will go to bios. Press f9 once. It will show load bios defaults with a yes or no popup. Press enter. Popup screen will disappear.  Press f10 once. It will show save changes popup with yes or no. Press enter. Computer will restart and it will load into windows.
    It might also be the issue with battery, charger or power outlet.   Try to use the charger in a different room on a different power outlet.  Try to bypass the surge protector and connect it directly to power outlet.    Try to use an alternative charger if possible.    Try to turn on the computer without the charger and check it  ( as long as the battery is not drained out )
    Try windows x
    go to device manager
    expand Battery
    right click on all the items below battery – uninstall
    Restart the computer
    It should work fine..
    I am not an ACER employee
                                         ★★ WILLIAM - MRK ★★
