How to always keep my laptop fan speed to its maximum & always keep the fan on Aspire A114-33-C9TX?
chaos51566
chaos51566 Member Posts: 5
I have a Aspire A114-33-C9TX and I want to always set my laptop fan to maximum speeds and always keep the fan on. Is there like anyway to do it?
  • Emma_
    Emma_ Moderator, Member Posts: 226 Moderator
    Hello!!
    @chaos51566
    The laptop CPU's are desiged with a higher TDP (max temperature).I don't think you can control Laptops Fan speed except for the gaming once of course. If you have heating issue, you can however remove and clean the fans for good airflow, other than that I dont think you can increase the fan speed on your laptop .
    You can check the power settings of your laptop with these steps
    Select "Control Panel" from the Start menu >Click “Hardware and Sound,” and then “Power Options.” A new window opens.
    Click “Change Plan Settings,” and then “Change Advanced Power Settings.” The “Power Options” dialog box opens.
    Select the “Advanced Settings” tab. Click the plus symbol associated with “Processor Power Management” to open an options submenu.
    Select “System Cooling Policy” from the submenu. Click the down arrow under “System Cooling Policy” to reveal a drop-down menu.
    Select “Active” from the drop-down menu to increase the speed of your CPU’s cooling fan. Click “Apply” and then “OK.”
    You can also try using a cooling pad if you have any heating issues with your device.
    Regards,
    LunaNova14
