R221Q Audio In not working? I'm using a DVI cable as a control so that sound isn't transmitted.
LemW
LemW Member Posts: 1 New User
edited April 2023 in Monitors
I have a 3.5mm lead plugged in, and I do not hear any audio. I know this monitor has speakers, so I am wondering why there is no audio. I'm using a DVI cable as a control so that sound isn't transmitted through it
  • Alejandro_AC
    Alejandro_AC ACE Posts: 14,963 Trailblazer
    edited April 2023
    Hi @LemW did you check the audio level for the 3.5 jack in the monitor controls?
    There are models that do not incorporate the audio option, yours may not have it.
    Thank you.
    All the best.
    • Un saludo / All the best
    • Haga clic en "Me gusta" si mi respuesta fue útil o márquela como solución si se resolvió, ¡gracias!
    • Colaborador pro bono, no trabajo ni hablo en nombre de Acer
    • Please click "Like" if my answer was helpful or mark it as solution if it was solved, thanks!
    • Pro bono contributor, I do not work or speak on behalf of Acer
    • Microsoft MVP (2003-21) - Windows Insider - (alezmvp)
