Acer Swift 3 sf315-52-58hg, problem with 1 core How can I fix this without changing parts?
cenity
cenity Member Posts: 4 New User
edited March 2023 in Swift and Spin Series
Hello!
I have a problem with my laptop, programs often close without errors, there are blue screens and freezes when installing programs.
When checking the processor on a laptop with the S&M program, it gives errors.
threads 0: Cache 1 level - failed, Cache 2 level - failed, CPU ( integer) - passed, CPU (FPU) - failed, Power Supply - 3.
threads 1: Cache 1 level - 3, Cache 2 level - 4, CPU ( integer) - passed, CPU (FPU) - failed, Power Supply - failed.
Other threads(2, 3, 4, 5, 6, 7) all passed.
As I understand it, the 2 threads in the core number 1 failed.
How can I fix this without changing parts? I saw somehow you can disable 1 core in the processor, but my bios does not have such a function.
  • cenity
    program prime95 also have error on worker 1:
    FATAL ERROR: Rounding was 5.174236985e+21, expected less than 0.4
    Hardware failure detected running 288K FFT size, consult stress.txt file.
  • Did you send the laptop in for repair at some point? This name is wrong:
    It should appear Swift SF315-52.
  • cenity
    Yes, this laptop was in service, it is not known about the repair, I bought it used
  • It is interesting to find out the reason for the repair. It is possible that the processor has a problem.
  • cenity
    in support they told me that there was a motherboard replacement
