GPU fan is constantly running 300rpm more than CPU fan. Can you help me?
Mert431135
Mert431135 Member Posts: 4 New User
edited March 2023 in Nitro Gaming
ORIGINAL
GPU fan CPU fana göre sürekli 300rpm daha fazla çalışıyor yardım edebilir misiniz.
TRANSLATED
[Edited the content by translating from Turkish to English]
Best Answers
    JackE ACE Posts: 45,182 Trailblazer
    Bu normaldir çünkü CPU ve GPU boştayken bile farklı hızlarda çalışan ayrı fan hızı denetleyicilerine sahiptir.
    This is normal because the CPU and GPU have separate fan speed controllers that operate at different speeds even when idle.
  • Commodore_1995#
    As colleague JackE said, it's normal. See an example:
    This can vary too, depending on the temperature.
  • leonaip
    leonaip Member Posts: 417 Specialist WiFi Icon
    the gpu fan needs cleaning using new paint brush or blower
    be careful while using blower as it may damage the fans (maintain safe distance between the blower and the fan)
    If my answers/solutions help you, please consider hitting "Like" and "Yes".
    Regards and God speed 😉
    Acer Nitro 5 AN515-58
    - Intel Core i5-12500H 12th gen Octacore ( 2.70 ghz... Turbo up to 4.50 ghz ) with p-cores and e-cores
    - 15.6 inch thin bezel IPS FHD ( 1920X1080 ) 144hz
    - RAM 8 GB DDR4 MAX 32 GB
    - SSD 512 GB Nvme
    - Nvidia Geforce RTX 3050 ( DEDICATED 4 GB GDDR6 )
  • Commodore_1995#
  • Mert431135
    bilgisayar yeni ve içini açtığım zaman temiz idi
  • Mert431135
    the computer is new and i faced this problem your advice put my mind at ease
     thank you very much
