Nitro 5 AN515-45 R4K8 unable to power up using battery, onle able to start using DC
azrinml81
azrinml81 Member Posts: 5
Anybody having this problem?batt shows 96% with dc power connected. As soon i remove power,it shuts down.
  • Commodore_1995#
    Try disconnecting and reconnecting the lithium battery as well:
    StevenGen ACE Posts: 14,981 Trailblazer
    edited February 2023
    Since you are able to use your laptop when it is plugged-in, that is an indicator that your charger adapter is not the issue, and also seeing that your laptop is max 2 years old the battery should not be faulty and in need of replacing but, check the battery condition first as at 93% charge it should have close to 19V output.
    If the battery is showing 93% charge and its got a less than 12V charge then that is a charging circuit issue that might be fried, which would prevent the battery from receiving more charge from the laptop and providing charge to the laptop when the AC adapter is disconnected which you will need to take your laptop to a technician for your laptop to be fixed.
  • Commodore_1995#
  • azrinml81
    egydiocoelho
    Thanks.Fixtheproblem.Basictroubleshooting.Appreciateit
