Orion 3000 seems dead changed power cable and tried different sockets
ibxxx
ibxxx Member Posts: 5 New User
edited January 2023 in Predator Desktops
Hi Orion 3000 i7 12700, 16gb ram, 1tb +512 SSD , geforce rtx 3070
It's dead won't start , changed power cable and tried different sockets
It was plugged in to a multi socket surge protected , I plugged in a usb cd drive and everything went off
All the other devices that were plugged in are fine , just pc dead .
The usb cd drive was plugged in to a usb socket on the pc , once I plugged the cd drive usb power supply everything went off
Pleas help
[Edited the content to add issue detail]
  • Jack22
    Jack22 ACE Posts: 4,609 Pathfinder
    @ibxxx
    May i have the model of the unit?
    Try doing a power drain and check. Unplug the charger and press and hold the power button for 30 seconds.
  • ibxxx
    edited January 2023
    There ya go
    [Edited the content to hide sensitive information]
  • ibxxx
    I just tried that and it didn't work
  • Jack22
    @ibxxx
    Than i guess it could be a hardware issue, Try to call Acer support.
    www.acer.com
    billsey ACE Posts: 36,340 Trailblazer
    Take the side cover off and watch the CPU fan when you press the power button. Does it spin at all? One of the first things that happen on a press of the button is to initialize the power supply, which provides the 12V needed to start that fan. If the fan doesn't spin at all we need to diagnose both the power button and the power supply itself. Do you have access to a VOM to measure connectivity and voltages?
    StevenGen ACE Posts: 15,081 Trailblazer
    edited January 2023
    Just in addition to all the above, don't touch your desktops PSU or dismantle it in any way, your Predator PO3-640 desktop should be under warranty, Let Acer fix your power on issues problems or an experienced technician if your desktop is not under warranty, Power related issues could be from many sources and opening a PSU is very dangerous if you don't know what you are doing, as you will get electrocuted,
    PSUs store high voltage when you open the unit even when unplugged from the mains power, understand that there are two hazards: Stored high voltage (200V or so) on the "input" side of the unit. and Stored high currents (tens of amps) on the "output" side of the unit. which are all very dangerous and lethal if touched "SO BE WARNED"!
