Aspire E5 Battery problem not charging but plugged in
PriyankaM
PriyankaM Member Posts: 1 New User
edited January 2023 in Aspire Laptops
Hi, My Aspire E5 series is plugged in and not charging.
  • Jack22
    Jack22 ACE Posts: 4,377 Pathfinder
    @PriyankaM
    May i have the model name of your unit?
    When the charger is plugged in do you see the charging light on the laptop?
  • wascas
    wascas Member Posts: 1,241 Overclocked Contributor WiFi Icon
    Try to reset the battery.
    Power off the machine and disconnect everything from the machine. Check whether there is a small pinhole on the back of the machine. Not all models have a pinhole. If pinhole is present, press into the hole for 5 s with a bent paper clip without a sheath. Then press the on/off switch continuously for 20 s. If pinhole is not present, press the on/off switch continuously for 20 s. Release the button and wait for 15-30 minutes. Reconnect the laptop to the power supply and wait for the full battery indication (blue) light. Then turn it on normally.
