Helios 500 cpu fan making noise rattling noise when the fan is running low speed
K3Z
K3Z Member Posts: 12
edited January 2023 in Predator Laptops
Hello, my helios 500 cpu fan is making something like a rattling noise when the fan is running low speed, as it gets faster the noise itself dissappears. My guess would be becase the cpu fan's wiring is running underneath it and the laptop is putting pressure on it so the wire is touching ? is there a way to dissassamble the fan so I can move the wiring abit away from the fan's blades? Because iam not sure how to open the fans case
[Edited the thread to add issue detail]
  • Jack22
    Jack22 ACE Posts: 4,511 Pathfinder
    @K3Z
    If you think its an hardware issue than take it to place where you bought it for replacement or send it to Acer repair center to fix it.
  • AnhEZ28
    AnhEZ28 ACE, Member Posts: 5,073 Pathfinder
    @K3Z Are you able to disassemble the laptop? If so, take a picture of the CPU fan to see if it is held by plastic rivet or screw
