Aspire E5 576G Battery problem my laptop doesn't get enough power, I'm currently using faulty?
Lumilion
Lumilion Member Posts: 4 New User
edited December 2022 in Aspire Laptops
So I had this problem where my Aspire E5 576G's battery didn't hold up so I took the battery out and used the original AC Power to power the laptop, and when i started to play games like Valorant the laptop shut down. Is this because my laptop doesn't get enough power and I need to get a higher watt AC Power or is the AC Power I'm currently using faulty?
[Edited the thread to add the issue detail]
    JackE ACE Posts: 45,219 Trailblazer
    >>>Is this because my laptop doesn't get enough power and I need to get a higher watt AC Power or is the AC Power I'm currently using faulty?>>>
    Exactly! During heavy game loads the battery has to help the charger meet the power demands. During those times, the battery actually drains even though plugged in. While a higher power charger would help, you risk damaging the mainboard due to power buffering and moderation that a good battery pack provides. New replacement battery packs are less than $30usd for this and related model. So I advise you to consider this rather than continue to risk damaging the mainboard. Google search 'e5-576g' 'battery' for vendors who ship to your location.
