acer aspire e15 battery problem, unit does not charge and overheats
akooo7
akooo7 Member Posts: 1 New User
edited November 2022 in Aspire Laptops
The battery of my acer aspire e15 laptop was pretty bad a few days ago, it was going for like 20 minutes. Today, it seems to be 0% full, but it doesn't charge. This is not a problem anyway, but after that, the pc started to overheat. I can't play video games etc. while plugged in. For example, yesterday lolde 220 I'm getting 30 hard today while getting fps. I would appreciate it if you could help
    data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABQAAAAUCAQAAAAngNWGAAABDUlEQVR4AYXRgUZDYRjH4TegFTKgpEqiFJgoWAoMEQGBgBboChaaAKxLKAhAhQqAdAmpBIQolkCFqp2nITvNKXuA7+/Hhzey5OWjE4Nq3rzY1f9/NGHPB549492+8Ww060iCS2XdctZdI3GsECmb+HJoIX6x6EgDm+lURTH+YB7V9nAqE5WNme4YKuOiY6iMe6PaQxUUIuTbswgFVNJwA8sO3Bn6yR6bWZMSNtJwDtuWfHpQxaPx9C9zadil7jrCigbq6UXceNIVKTWUIqypm2ytJdTiNyNeXclF6GttOVfeDEc7qzjR23r3OMFqZKng1kw0mXGLrfibHTScOZWgGv9TdC6ROFeMTgwYiIxvJzMRWQbeGZUAAAAASUVORK5CYII=
    There was an error displaying this embed.
  • Balatekie
    Balatekie ACE Posts: 1,353 Pioneer
    Hello!!
    @akooo7,
    From the description shared, I seems that battery has gone bad and you need to replace it. This can be confirmed, as unit is getting heated up and also FPS drops. Since, battery does not work.. laptop Power Options tend laptop to run in Power all time. That might be force high performance mode. That could be the reason for heating up and FPS dropping.
    Hope this helps!
    Regards,
    Balatekie
     :) If you think I've answered your question, please hit the Accept Answer:)
