2019 Predator Helios 300 crazy symptoms - all at the same time:
When plugged in, battery shows charging, but stops and gets stuck @ 96%
Slightest movement of power cable connector at the port causes laptop to shut down.
Completely shuts off when unplugged
Will not turn back on, or run, with just the battery
I turned off laptop, removed back cover, unplugged the power port connector, & unplugged battery connector.
Held down the power button for 15 seconds, then plugged the battery connector and power port connectors back in.
Battery started charging, said "15 minutes till full charge".
Now shows "fully charged (100%)"
No movement of the power cable connector causes a shut off.
Computer turns on and runs with battery again.
Hope this is helpful
