Acer nitro 5 AN515-54 GPU fan max speed not same as cpu fan max speed (6000/6122)rpm
andalib
andalib Member Posts: 57 Enthusiast WiFi Icon
hi everyone
after I recently cleaned my laptops fan and added some thermal paste to it the gpu fan max speed got slowed down to 5769 or sometimes 5882 rpm is there any fix for it? i used to get both fans by 6000/6122 rpm before cleaning....
laptop model - AN515-54-760U (Australia)
Bios version : V.133 Bios date : 11/17/2020
Windows version: Windows 11 latest......
    StevenGen ACE Posts: 15,036 Trailblazer
    Its because your GPU is running hotter hence the fan speed is higher to cool the GPU. As long as your laptop is maintaining good temps don't worry about it.
  • andalib
    no it wasnt like this before it was both 6000rpm before...
  • AnhEZ28
    AnhEZ28 ACE, Member Posts: 5,103 Pathfinder
    @andalib I have the same model and this is pretty much normal to me. Because the GPU fan has two vents, it doesn't work as hard as the CPU fan. These RPMs can be an indicator to know when you need to clean the vents. If both fans are running at 6122RPM, chances are dust is currently blocking the vents.
  • andalib
    I cleaned vent and everything including fan blades with water and warmed them using my hair dryer....
  • AnhEZ28
    @andalib I mean lower RPMs are fine because those vents are free. Blocked vents make the fans work harder.
  • andalib
    edited January 2022
    is there any fix like can i reset bios or battery reset or like reset fan drivers etc??
  • andalib
    Someone help
  • AnhEZ28
    @andalib it should be like that so you don't have to worry. You can try using your hand to block the vent near the charger port. The GPU fan will increase a bit but will drop down after you put your hand away.
  • andalib
    i think something weird and creepy happened after i clean my pc and test the fans while covers were opened the pc suddenly shutted down and after that i noticed that my gpu fan speed went down for some reason also for some weird reason i got the LCD overdrive option On Both Nitrosense and Predatorsense but my PC model is 60HZ is there any recent bios Update that caused both this Gpu fan rpm problem and LCD overdrive option for 60hz nitro 5 models??? btw i also tested with NBFC and set both cpu and gpu fans to 100% so cpu was able to hit 100% but Gpu hit upto 96.1% i cleaned my pc several times resetted both bios and battery but doesnt fix.....
