Aspire A315-34 won't turn on and no power or battery light
I have an aspire A315-34, it was working fine for a few hours this morning and then switched off randomly without warning. I've tried doing the battery reset with a pin in the hole and leaving the laptop for a while before trying to turn it on. Pressing the power button isn't working, there's no sign of the laptop starting at all, no noise from the fan and the power light isn't coming on. I've tried plugging the charger in and pressing the power button, still nothing. When I plug the charger in the charger light on the laptop doesn't come on.
I had just plugged the charger in cause the battery was getting low and didn't have long left and it just switched off. Could it be a problem with my charger or the battery? I have no way to test the charger in another device or try another charger in my laptop.
This has happened once before but resetting the battery worked then. This time it doesn't seem to be doing anything. Does anyone have a solution?
