query about battery battery drain issue Nitro AN515-43
Arkajyoti
Arkajyoti Member Posts: 2 New User
edited July 2021 in Nitro Gaming
last 20-30 days my laptop gives me only 1.5 hours of backup while online classes. Before that, it gives me a 2.5 hours easily.
if I want to work a application through redion 560 grafix card then what should i do in acer
Nitro AN515-43.
but when I check battery health it shows good.
RAM management is very bad.
I can't even install after uninstalling some applications.
very bad experience with this laptop.
  • Arkajyoti
    please anyone help me what should i do.
  • Easwar
    Hi Arkajyoti,
    # Try to update the battery driver
    1. Hold windows key and hit letter X.
    2. Choose the device manager option.
    3. Go with the option battery.
    4. Under the title battery.
    5. Right click on that option ----> Update all driver under the title battery.
    6. Choose "search automatically".
    Check this T/S and post the result. ​
