Low GPU a problem with FPS on games FPS (50) on Ultra and low settings - nitro 5 AN515-54
Danieltm95
Danieltm95 Member Posts: 3 New User
edited March 2021 in Nitro Gaming
Hello I’m have a problem with my GPU on games like call of duty warzone, I have MSU afterburner running to see the GPU usage and its a 50%,  I get the same FPS  (50-60) on ultra Settings and (50-60) on the lowest settings posible.
Pc: nitro 5 AN515-54
intel core i5-9300H CPU @2.4 GHz
16gbs RAM
rtx 2060
I have upgraded all the drivers Twice and Update windows to the latest update,
I also did all of these things
1- all drivers and Windows must be properly updated
2- the device must be set to use the Windows high performance power plan
3- seven the minimum and maximum performance of the processor at 100% in both modes (both on battery and plugged into power outlet)
4- the battery must be charged to 100% before playing
5- the battery must be set to advanced power options for maximum performance
6- game applications must be set on the dedicated GPU Panel (Nvidia) to be the main
7- the device must be connected directly to an exclusive power outlet, properly grounded without any adapter
8- batterybooster must be deactivated
9- disable the FPS limit
10- seven Intel HD Graphics for maximum performance
11- uninstall all Microsoft X-Box applications
12- disable the DVR recorder
13- enable the maxframerate option in the nvidia control panel
13- all games must be installed on the same disk drive and partition as the.
14 - tried installing the last 10 drivers and nothing worked.
GPU temperature 60-70C
CPU isn’t at 100% , it’s around 85% - 90%
 I also formatted the whole pc and reinstalled windows and everything.
I don’t know what’s going on.  Someone please help me.
​​​​​​​​​​​​​//Edited the content to add model name on title.​
