My lap E574G, In sometimes, when power button press LED on but no display and CPU Cooling fan Speed
Shan123
Shan123 Member Posts: 49
My lap E574G, In sometimes, when power button press LED on but no display and CPU Cooling fan Speed Up And speed down automatically... at that time long press power button and turn off and try power on it works... and some times when connect the chager and power on normally it works...
  • What is the exact model? Example E5-574-58VH. Does the same problem occur when resetting the battery?
  • Shan123
    E5-574G-57E9 Moddle.. in battey 20% also it works (Included original battery)
  • Oi! Eu não sou sou a cortana! Mas estou aqui para ajudar! Hi! I'm not the cortana! But I'm here to help!
  • Shan123
    Did it... but no solution
  • Does your model have these two buttons?
  • Shan123
    CMOS battry reseted.. main battery plug removed for 10 min after at that time laptop normally power on. but after few days same problem happen
  • Shan123
    only one button have like this
  • I suggest that you take the laptop apart and check these buttons:
  • Shan123
    did you mean that reset buttons?
  • There are two buttons:
    a) the battery reset button;
    b) and the interlock button
    I think the interlock button is not being pressed properly.
