AN515-54 fan noise and speed problem
Mikeesw
Mikeesw Member Posts: 2 New User
Hello, I am currently experiencing a problem on my gpu fan. It is making a sound that is really loud. My pc has crashed a few times already like the audio and monitor would freeze. I have no choice but to reboot. The fan speed of my gpu has been low compared to my cpu. Please help. I do not know the most efficient solution. Right now we. We can't go to acer's facility due to the pandemic and they do not support the item to be delivered to them. If I need to get a new fan. Should I replace one or both? Does all nitro 5 brushless fans are the same? If not what fan version is recommended?
  • Mikeesw
    I have check the fans and the one at the left (back facing me) is harder to spin at small finger pressure compare to the one at the right which moves fast with a light finger turn.
  • Rudy21
    Rudy21 ACE Posts: 1,787 Pathfinder
    I would suggest you to contact Acer support and report the issue.
    Click on 'Yes' to accept my comment as answer
