CPU FAN SPEED LESS THAN GPU FAN SPEED??(NITROSENSE)
tipsy
tipsy Member Posts: 11
Hi. Just wanted to ask if its normal that the cpu fan speed is lagging on the gpu fan speed? If not, how can I fix it?
  • batmalin
    batmalin Member Posts: 4,231 Guru
    Yep, it is normal. Your laptop has 2 fan controllers (not enabled for you to control) controlled by EC (Embedded Controller) set by Acer. Only Nitro/PredatorSense has access to it thou.
    Please click "Yes" if I have answered your question.
    Userbench: https://www.userbenchmark.com/UserRun/31177158
