XV272UV: My first 2k HDR monitor. Need help optimizing settings.
Sorry to ask such basic stuff, but I've never had a fancy monitor before.
When it comes to turning on HDR, should I enable the HDR toggle in the Windows 10 display settings (which seems to make the colors look washed out), or just use the HDR "mode" on the monitor settings?
In the Picture settings on the monitor, for HDR, i can select "off", "Auto", or "HDR-400". What's the difference between Auto and HDR-400?
As I get used to this monitor, I feel like it's too bright for right now. Do I lose anything by turning down the brightness?
What is "VRB", and why can't I have it enabled at the same time as Free-Sync, or if HDR is enabled on the monitor?
I really like the ACM feature, but why is it disabled when HDR is enabled?
In HDR mode, is there anyway to make the colors less warm?
What is "Over Drive"? Is that how I can "overclock" the monitor to get the refresh rate up to 170hz?
