A315-41 -R95 is not turning on after pressing power button but power light stays up for few seconds.
mit
mit Member Posts: 4 New User
edited October 2023 in Aspire Laptops
I have aspire 3 ryzen 5 laptop, the laptop is not turning on after I pressed the power button but the Power light stays on for some 6 seconds and then goes off .
I have ensured the battery was charged and I don't know surely how to reset battery by the pin hole present back . I have tried to hold it for a minute it didn't work for me.
It's under warranty but it got it's keyboard replaced by Acer service center just a day ago and worked finely after bringing it to home and now it's having this problem , please help
[Edited to add model name]
    JackE ACE Posts: 44,868 Trailblazer
    Remove the charger. Then press and hold a paperclip into the battery reset pinhole on the bottom for another 30-60 seconds while also pressing and holding the power button. Then plug the charger back in BUT don't try to turn it on until the battery charge light changes from orange to blue. Jack E/NJ
  • mit
    I have tried it it doesn't seem to work
    But one thing is the laptop turns on once a day like it I turn it on morning it will stay with out any problem but once if I make it sleep or shut down it never turns on the same day maybe after. 10+ hr gap  it will turn on. So as if I turn on next morning it does.
  • what is the exact model? example a515-51-58vh. does your model have this button?
    Problema Bateria Notebook Aspire VX 15  Acer Community
  • mit
    The model is A315-41 -R95S    ,BIOS version is V1.13 ,I think it doesn't have that button I have attached a photo to confirmegydiocoelho said:
  • Oi! Eu não sou sou a cortana! Mas estou aqui para ajudar! Hi! I'm not the cortana! But I'm here to help!
  • peggyriley
    peggyriley Member Posts: 1 New User
    A laptop has several phases of “just won’t start.” The problem is compounded because a laptop has two power sources: When AC isn’t available, electricity is drawn from the laptop’s battery. So you know immediately that when the laptop doesn’t turn on right away, you have a power supply issue. If the laptop appears dead, you have a power supply issue. Here’s how to troubleshoot:
    • Check to ensure that the laptop is plugged in.
    • Check to ensure that the battery is properly installed.
    • Try removing the battery to run the laptop from just the AC power. If it works, you may have a defective battery that needs replacing.
    • If you have a second battery, use it instead.
    • Check the power brick on the AC cord. Is it the right adapter for your laptop? Other portable devices may have similar-looking adapters, but unless they match the volts and amps for your laptop, the laptop doesn’t work. (Not that this has ever happened to me.)
    • Volts and Amps would be great team names. Imagine them playing each other. It would be electric.
    • When the laptop’s power lamp is on, it shows that the laptop has some life. It means that the laptop’s hardware is recognizing that it has power. The problem could then lie with the laptop’s hardware, not with the power supply.
    • When your laptop has separate lamps for the AC power and battery, you can check both. If the AC lamp lights but the battery doesn’t, it’s a battery issue. When the battery lamp is lit but the AC lamp remains dark, the AC power brick might be dead or the AC power from the wall might be messed up or you might have a connection issue.
    • If you consider yourself to be technically proficient, you can try testing some hardware. For example, if the laptop has removable disk drives, check to ensure that they’re properly connected: With the laptop’s power off, take out the drives and put them back in again. Ditto for the PC’s memory card: Turn off the laptop, remove the memory, and then put the memory back.
    • Laptops don’t start when they’re broken. I’m not being flip, either: Laptop hardware can fail. Failed electronics are covered by most laptop warranties. You need to get support by contacting the laptop manufacturer.
    • Press the Caps Lock key. If you have power, the Caps Lock lamp on the laptop will blink on and off as you press the key. If so, the problem could be the display.
    • Check the laptop display’s brightness settings. If the brightness level is turned down too much, the screen will be dark, especially in a bright room or in direct sunlight. Try turning up the brightness all the way to see whether the screen glows.
    • Plug an external monitor into the laptop’s monitor port. If the external monitor works, the problem is with the laptop’s display only, not with the laptop’s display adapter or other internal hardware. Because the laptop and monitor are the same thing, fixing the monitor (or the display adapter) involves replacing major laptop components. You must return the laptop to the dealer for repair.
  • Easwar
    Hi peggyriley,
    May I know the full model name of your unit.
