When I pluged inthe charger ,red light is not blinking and it's not receiving the power
Harishkatta
Harishkatta Member Posts: 1 New User
On desktop it's not showing the battery percentage
    billsey ACE Posts: 36,312 Trailblazer
    255% available shows that the Windows battery info is corrupted. It should always be a number between 0-100%. :) Do a battery recalibration. Run the laptop on battery power until it shuts down due to low battery. You might have to tweak your power settings to allow it to run that long without sleeping. When it's shut down plug the power in and let it charge fully before turning it on. Rinse and repeat a couple of times and those numbers should get back to normal. 255 in programming terms is actually -1.
