Help me fix '' There was a Problem resetting your Pc . No Changes were made '' Problem.
DMB7777777
DMB7777777 Member Posts: 9
Hey Guys,
I need a little help. I tried to reset my Acer Predator Helios 300, but every Time I get an error which says, there was a problem resetting your Pc. I tried out some tutorials from Youtube, but nothing Help.
Can someone Please help mewith this Problem?
Tthank you in Advance
Edited the content to hide personal information
Acer-Samuel
    StevenGen ACE Posts: 15,036 Trailblazer
    Hey Guys,
    David
    Firstly, why are you trying to "Reset" your system? As there are other means of fixing problems. Try to take your system back to a "Restore Point" first, to do this, type into the left bottom part of the taskbar at "Type here to search" type in "restore points" and the "System Properties" will appear, click > System Restore and go through the steps and chose your last and most resent "System Restore Point". After that try Reset, if you still want to Reset your system? As there could be a system problem and the Reset option cant set all the settings for a successful reset, try these other 6 Ways to Repair or 'Factory Reset' Windows 10, good luck.
    1. Use a Restore Point within Windows 10
    2. Issue a Restore from a Disk Image Backup e.g. a backup like Macrium Reflect etc
    3. In-Place Upgrade / Repair Install
    4. Repair Windows 10 using Install Media
    5. Reset Windows 10 from within Windows 10
    6. Use a Recovery Drive to Repair, Reset, or Refresh
    7. Reboot and Install Windows 10 Fresh
  • RanY2J
    RanY2J Member Posts: 599 Seasoned Specialist WiFi Icon
    Hey Guys,
    David
    When Windows cannot boot, it launches a recovery mode to reset the OS, if the recovery is also corrupted, you get this message. Best option is to do a Fresh Windows installation. However, you can also try this: https://www.kapilarya.com/there-was-a-problem-refreshing-your-pc
    BElieve in YOUrself.
