Code 10 for Intel Management Engine interface and Intel serial I/O I2C causing touch pad to not work
Phantomz
Phantomz Member Posts: 10
edited October 2023 in 2020 Archives
Recently after doing a repair for the C drive using the tool from windows the computer restarted and now the touch pad no longer works. And on device manager 3 devices have  error code (10), Intel Management Engine Interface,Serial I/O I2C 9D60 & 9D61.
Laptop: Acer Aspire A515-51G
  • Commodore_1995#
    Commodore_1995# ACE Posts: 98,343 Trailblazer
    No. Try reinstalling windows like this:
  • have you tried to uninstall and delete the drivers?
  • Phantomz
    Yes im going to try doing it again ill let you know if it works
  • Phantomz
    ive tried doing that just now including deleting the software but when i restarted they are their again with the same error
  • Phantomz
    edited April 2020
    i've tried startup repair but it didnt fix it
  • Commodore_1995#
  • Phantomz
    Oh sorry my bad i did the alt-f10 before boot but it took me to startup repair
  • Phantomz
    Ok I will reset the pc and let you know if it fixes the problem
  • Post the result here.
  • Phantomz
    Hi there,
    Thanks for your help. After resetting the PC the touch pad works now. I will mark your answer as solved.
  • you are welcome.
