Battery Problem need help Helios 300
Jayceeoh
Jayceeoh Member Posts: 8 New User
Hi there. I've had my Helios 300 for about 9 months now. Just the other day, either my battery or my charger seems to be acting weird. Every 10-15 seconds or so, my screen dims, and laptop "beeps" that my battery is not charging, and then a few seconds later the screen will get bright and "beep" that it is charging again. The charger is plugged in the whole time it is doing this. I tried resetting the battery by putting a paperclip into the battery reset simulation button at the base of my laptop, but that did not work. Any suggestions? Does it seem like there is a problem with the battery or the charger? Thanks.
  • Sathish2388
    Sathish2388 Member Posts: 85 Fixer WiFi Icon
    Jayceeoh .. Hi! please follow the below steps
    1. Shutdown your computer and then remove the power cable ( AC Adapter) from your computer
    2. Look underneath your laptop you could see a small battery reset pinhole where you have to insert paperclip and hold it down for 10 to 15 seconds then remove the paperclip
    3. connect the AC adapter then turn on the computer and check whether the problem is resolved if not got to step 4
    4. Get on to device manager by clicking on start and type device manager in search box
    5. In device manager expand Batteries and whatever you see under batteries uninstall them then turn off your computer
    6. unplug the power cable from your laptop
    7. Press and hold the power button for 10 seconds and Connect the power cable then turn on your laptop and check it's resolved your issue or not..
  • xapim
    xapim ACE Posts: 7,240 Pathfinder
    edited December 2019
    Jayceeoh if any of the above wont sort it out check your adapter with a voltmeter to see if its working fine and check your battery report for the wear
    Also just to add if its a 2019 h300 doesnt have a battery pinhole its the power button and whichever you have press/hold for 30s and let the laptop rest for 2/3h check here to completely discharge all capacitors boot into bios and reset to default settings
    https://www.userbenchmark.com/UserRun/11532543
    UserBenchmarks: Game 43%, Desk 61%, Work 40%
    CPU: Intel Core i5-7300HQ - 63.5%
    GPU: Nvidia GTX 1050-Ti (Mobile) - 41.9%
    SSD: WDC WDS200T2B0B-00YS70 2TB - 71.4%
    HDD: WD WD10SPZX-00HKTT0 1TB - 93.7%
    RAM: Kingston HyperX DDR4 2666 C15 2x16GB - 76.8%
    MBD: Acer Predator G3-572
    I'm not an Acer employee. (just here to help in the best way i can)
    If my answer fixed you issue please accept it for any other users who search for it would find it quickly thanks :)
    If you want to learn more about undervolting/optimizing windows join the Predator fb group and youtube channel:
    Owner/Admin (HOTEL HERO/Red-Sand/Opoka Opoka)
    https://www.facebook.com/groups/PredatorHelios300
    https://www.youtube.com/channel/UCNJwGUHxSJ8FKqAhnOqQuAw
    Acer support:
    https://www.acer.com/ac/en/US/content/service-contact
    http://www.acer.com/worldwide/support/
  • Jayceeoh
    i just tested my adaptor and everything's works fine but i dont get why it still geting that beeping.. its anoying and i cant edit that much ..cuz sometimes the battery using my proccesor and cant fully edit videos... or play
  • Jayceeoh
    it may be also because i have my windows in legacy. cuz i couldnt install it on UEFI it wont boot... and idk why. ps its a helios 300 ph317-51 16gb ram, nvidia 1060 and i770hq
  • xapim
    Why do u have your windows in legacy mode and why have u installed it for windows 10 to work as it should needs to be with secure boot on uefi
    Acer support:
  • Jayceeoh
    i was trying to do it in UEFI mode but dont work because it wont boot.. i already put everything in order in bios. also the secure bot is disabled and when i press F10 to boot from usb it gives me an error like i need to fix my computer and wont boot...
  • Jayceeoh
    P.S i already did the thing with reseting the battery and uninstall them from manager, still dont work...
  • xapim
    For windows to be installed the normal way secure boot needs to be enabled and the bios in uefi mode if you have it disabled as you stated it wont work wont let you boot at all secure boot only needs to be disabled for any other OS to boot from usb drive
    Acer support:
  • XdxD
    XdxD Member Posts: 1,592 Community Aficionado WiFi Icon
    For clean installing Windows 10 using USB, use the Rufus tool to create it. Then, keeping BIOS mode as UEFI, turn off secure boot. Works like that on all PCs with UEFI BIOS. Also, try doing the pin-hole reset again by keeping the pin pressed for 10s. Then connect the adaptor and boot to BIOS. Reset the BIOS to default values (remove your Supervisor password first) and then choose "Save and Exit". This solved it for me last week. Use this guide.
    Trying to do my best here - Your happy Predator owner =)!
  • Jayceeoh
    i already did that... and it gives me an error. this one... i dont know what to do..
  • XdxD
    Try the steps once mentioned here (needs an ISO I think). Also look at this thread.
  • XdxD
    You can also visit the service center if under warranty for fixing it.
