Acer aspire 4830g shutdow after a few second. Only power LED lights up. Fan not working.
Cranonacrane
Cranonacrane Member Posts: 1 New User
edited August 2023 in 2018 Archives
My old laptop acer 4830g's screen has been flickering lately so I decided to take it apart to look for solution. After tinkering for some time it ran into the title's issue. I've tried power resetting by press holding the power button for > 15 sec; reinserting ram/any cable possible on the board but the problem persisted. Appreciate some insights for this
Comments
  • RaoR
    RaoR Member Posts: 47 Devotee WiFi Icon
    Cranonacrane,
    These flickering issues happens when the operating system is corrupted / due to hardware issue. I Would recommend you to do the following
    a) do power drain (remove battery & unplug the charger, then press and hold the power button for 20 secs
    b) boot into the BIOS screen( while turning on, keep tapping on the F2/del key to boot in BIOS) - Stay in the BIOS screen for some time and check whether the screen is flickering in this mode, IF it flickers - it is hardware issue - please contact local tech or Acer repair center in your region.
    If it doesn't flicker - press F9(set BIOS defaults)and F10. restart the pc in safe mode networking - take backup of your data and do factory reset.
    If I helped, please click "Like"
    If I answered your question, please mark my post "accept" to make it easier for others to find the answer!
    Regards,
    RR
    Hi! I'm not Cortana! But I'm here to help! Click "Like" if you find the answer helpful!
    Click "Yes" when the comment answers your question!
    Regards,
    RR :)
