Laptop won't turn on or charge, battery reset button and un/replugging battery won't work
My acer nitro black v15 shut off while plugged in and fully charged. It had a Styrofoam platform with holes cut so it can breathe. I wasn't doing anything that RAM intensive. It was very hot, but it gets this hot often. I cooled it down quickly with a fan, but it won't charge or turn on now.
I've tried resetting the battery with the button on the back, pressing it for over 4 seconds, plugged in or not, then waiting awhile, then pressing power.
I tried unplugging the battery, holding the power button for at least 30 seconds, plugging the power cord in, then replugging the battery, then pressing the power button
Neither of these worked no matter how many times I tried.
Is it possible it's just the power cord? It's worked fine up to this point but I did recently replace the cable.
My warranty is up, so if it doesn't work, should I send it to acer or take it somewhere locally?
