Need help finding a replacement battery for Acer Aspire 5732Z Series Model NO. KAWF0
DJENT
DJENT Member Posts: 5 New User
edited November 2023 in 2018 Archives
Battery Specs:
AS09A31
3ICR19/65-2
Rating: 10.8V
4400mAh, 48Wh
Lithium Ion Battery Pack
Please help!
  • laurent_14
    laurent_14 ACE Posts: 10,399 Trailblazer
    Hello,
    Here are the part numbers of the original batteries for this laptop:
    BT.00603.076 BATTERY.6C.4K4mAH
    BT.00604.030 BATTERY.6C.4K4mAH
    BT.00605.036 BATTERY.6C.4K4mAH
    BT.00606.002 BATTERY.6C.4K4mAH
    BT.00607.066 BATTERY.6C.4K4mAH
    BT.00607.067 BATTERY.6C.4K4mAH
    BT.00607.068 BATTERY.6C.4K4mAH
    Yours is the first one.
    France
  • DJENT
    Hello,
    Thank you so much! Just to make sure, will it work with this model: Aspire AS5732Z-443G25Mn?
  • laurent_14
    You're welcome. Yes all these part numbers are compatible and will work with your laptop (100% sure). FYI, AS5732Z means Aspire.
    France
  • DJENT
    Could you give me a faster way to contact you please? (skype, discord, whatsapp etc)
  • laurent_14
    Sorry but it's not possible and I'm not an Acer employee.
    France
  • DJENT
    edited May 2018
    Where would you recommend buying one of these batteries? I found lots of batteries from the same seller on newegg (Ebuy limited) that seemed like they could be compatible, but I'm not really sure... I would be really grateful if you could help me find a store to order from.
  • DJENT
    Help me... :(
