Optical drive Parts for Aspire F5-573T
michael_e_owen
michael_e_owen Member Posts: 1 New User
I recently bought an Acer Aspire F 15 laptop - Module # F5-573T-56UC (SILVER) which came without an internal optical drive. Instead it has a dummy filler-component occupying the aperture and blank grey faceplate/bezel) .
Does anyone know the Part numbers I would need to search for and install an optical drive (DVD-Writer) INCLUDING the BEZEL/FACEPLATE in this Model?
I understand from friends that while most internal 9.5mm drives will fit, the real problem comes with getting a comaptible ODD Bezel or Faceplate (with Button & LED) and which would fit the shape of the right hand base edge of this laptop base.
(The laptop base is grey in colour - simce the laptop itself is the "SILVER" option).
Are there other Acer laptop ranges (e.g "Aspire E5") whose Optical Disk Drive (ODD) aperture and faceplate would be the same size and shape as that for the Aspire F5 seriers?
Any help or advice you can give me would be very much appreciated.
  • laurent_14
    laurent_14 ACE Posts: 10,400 Trailblazer
    Hi Michael,
    About Aspire F5-573T:
    If you remove the dummy ODD, do you see a SATA connector in the bottom of the housing?
    LT-ODD SATA connector
    France
