Acer Liquid E700 sound problem, does not ring or alerts when someone calls
sapphire21
sapphire21 Member Posts: 5 New User
Hi, I had an Acer Liquid E700 phone, it was 4 months old,the problem here is the sounds for incoming calls and sms was never heard. Also when I call someone, they did not hear me clearly. I tried calling to others but they also claim the same problem with my line. They only hear a little sound. Also th earphones was not working on the mobile.
Can someone help me with this problem? What was wrong with my mobile?
I haven't drop this.
Thank you in advance..
  • IronFly
    IronFly ACE Posts: 18,412 Trailblazer
    try a factory reset, just to check if it's a software issue, remember to backup your personal data first:
    settings/backup&reset/factory data reset
    if the issue persist, contact your seller or Acer support service.
    I'm not an Acer employee.
  • sapphire21
    hi.. thank you for your response.. but i already try that method but it was still the same.. Smiley Sad
  • IronFly
    so...Contact your seller or Acer support service, probably an hardware issue.
