How do I get sound from my S271HL monitor using a DVI cable and a sound cable?
RichardGough
RichardGough Member Posts: 3 New User
Why does my computor not give any sound when it is connected with a DVI cable and a sound cable.
  • Blayn-Acer
    Blayn-Acer Administrator Posts: 2,355 Community Administrator
    Most S271HL monitors do not have speakers. Can you please send me your serial number, so I can confirm if this monitor supports audio? Does your sound work if you hook your speakers or headphones directly to your computer?
  • RichardGough
    MMLUWAA005439095258535 IS THE SERIAL # AND YES I GET SOUND FROM MY SPEAKERS WHEN THEY ARE PLUGGED IN.
  • Blayn-Acer
    According to the serial number of this product, I do not show that this model shipped with speakers. I apologize for any inconvenience.
    Regards,
    Acer-Blayn
