Hello, first of all, I use a translator, so please understand that the sentence may not be natural.
I'm using NITRO V16 (ANV16-41).
Ryzen 7 8845HS
GeForce RTX 4060
It's the version.
The traditional BIOS is version 1.14.
Battery drain occurred in games or other high load situations.
Drains occurred in balance, performance, turbo mode except silent mode.
At first, ACER responded that it was such a designed laptop.
But after reading below on Reddit, I think it's a problem that ACER can solve enough.
https://www.reddit.com/r/AcerNitro/comments/1o2263v/i_found_a_fix_for_nitro_v16_battery_drop_while/?sort=old
The information is
In Ryzen version Nitro V16, if you use BIOS version 1.04
This means that there is no battery drain.
I also downgraded the BIOS version to 1.04 as a test, and there was no battery drain.
(Of course, I didn't know what would happen after the test, so I versioned it back to BIOS 1.14, and the battery is draining again.)
No battery drain occurred in silent, balanced, and performance turbo mode.
If ACER has not distributed a BIOS that has a battery drain to hide any design defects on the product, please correct the problem in the BIOS again.
I bought a Nitro V16 because of its good performance for the price, and I was quite satisfied with it, but after learning that the battery drain occurred, I'm thinking about buying an ACER product for the next laptop.
Please fix it in the BIOS and solve the problem.
