Need Help Finding Fan Replacement for Predator PT515-51 – Loud Noise Issue
SwimmingDove
SwimmingDove Member Posts: 1 New User
Hi everyone, I’m hoping someone can help me find a replacement fan for my Predator PT515-51. One of the two fans in my laptop (I believe it’s the GPU fan, not the CPU fan) is broken and makes a loud, grinding noise whenever I start the PC. I’ve taken it to a local PC repair shop, but they’ve been unable to source the part I need.
I’ve tried looking online, but I’m not sure where to find a compatible fan for this specific model. Does anyone know where I can buy a replacement GPU fan for the Predator PT515-51? Are there any reliable third-party sites, or perhaps someone has a spare part? I’d really appreciate any suggestions or advice on how to resolve this issue. Thanks in advance for your help!
  • Sharanji
    Sharanji ACE Posts: 4,839 Pathfinder
    edited March 28
    @SwimmingDove
    You need to check if the GPU fan is separately available for this model. The part number of the set that includes the fan is listed below. You need to google it to check the availability. Also, check with these Acer part partners Acer Part Partners
