Hello,
I got a predator helios 18 and i noticed that i can only rely on using the manual fan speed and then keeping it on max even it this is not needed all the time and it makes noise.
There is a function where you can put the fan speed on auto for CPU and GPU. For some some reason this function does not work properly. The fan speed remains low while CPU is heating into 90% +. It should go max speed. I dont hear the laptop regulating this.
Also when laptop is on idle it seems that fan speed is shutting down completely. So laptop not doing anything but its still on. So of course it will heat when laptop is still on and fan is not working.
What is the problem with this 'auto' function?
