SFG16-72T laptop fan randomly ramps up to max speed for 10 seconds, what app controls fan speed?
ClueJess
ClueJess Member Posts: 2 New User
edited February 11 in Swift and Spin Series
My laptop is only one month old, and when idle with basically zero apps running other than maybe firefox, it will just randomly ramp up the fan to max speed for a 10seconds seconds and then stop. What app controls fanspeed?
SFG16-72T
[Edited the thread to add issue detail to the title]
    Fan speed is controlled by the BIOS, not an app. You might be able to change which fan table is used, they often have normal, silent and performance options. That would likely be set in Acer Care Center.
  • ClueJess
    I don't see an option for normal, silent, or performance in Acer Care Center. Acer sense does have those options though
    StevenGen ACE Posts: 15,212 Trailblazer
    edited February 12
    See this guide here How to control Fan Speed on Windows and use a 3rd party fan speed control app. as Acer does not have any app for fan speed control for your SFG16-72T laptop. Good luck and hope this helps you out further.
    So, Acer Sense is the app that control it on your model then.
